Re: 450 lp will start up but will not keep running
Posted by Centex Farmall on November 12, 2014 at 18:14:35 from (72.105.161.120):
In Reply to: 450 lp will start up but will not keep running posted by rustyrelic on November 12, 2014 at 17:08:57:
Is the choke working on the carb? You probably have a "sticky" regulator. If you can get it to run with the choke on it may loosen up a bit. The regulator requires a vacuum signal to tell it to open up. Also there is a filter between the tank and regulator. They don't usually clog but it's possible. Loosen a fitting on the line between filter and regulator with the vapor line on and see if you have some pressure.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
