Re: throttle lever/linkage or governor problem
Posted by mkirsch on November 14, 2014 at 05:14:35 from (72.45.143.81):
In Reply to: throttle lever/linkage or governor problem posted by puddingstone99 on November 13, 2014 at 15:44:58:
The rod running from the throttle lever to the governor on the C tractors is very long and flexible, with a couple of "kinks" in it to get around various things. If it is not properly supported along the way it will want to flex instead of pushing the governor arm.
We've got the same problem with our Super C. We've fiddled with it some and improved things, but it's very easy to screw up. At one point we had the throttle rod jamming into the fan blades.
There should be a couple of clips to support the rod along the way. One on the hydraulic block, and one further forward on the engine.
