It has been quite a while since I had one of them in pieces, so I need to say AS I RECALL. Others will be along and confirm correct.
The seal is pressed into the cover from the inner side, so the cover needs to come off. The pulley MAY have a setscrew to remove first (if some early A parts have migrated onto it). In any case, the pulley will be hard to pull off. You will need to back up the pulley with a large bearing separator. Screw a bolt into the end of the crankshaft (until it bottoms) to push against. The pulley may have a groove worn from the old seal. If so, ready sleeves are available to provide a new seal surface. I believe Case-IH has seals packaged with a wear sleeve. When you install the front cover, leave the bolts loose so the seal can self-center when the pulley is installed. Tighten the cover after installing the pulley. The pulley goes on much easier if you warm it first. A toaster oven set at about 250 works well, as does letting it sit in boiling water or heated oil. Screw some all-thread into the front of the crankshaft and use appropriate plates/washers and a nut to pull it on.
You can search for past posts with more details/suggestions on removing the pulley.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
