Re: Please Help! Farmall H 1948
Posted by charlie M on November 14, 2014 at 07:08:17 from (24.39.229.234):
In Reply to: Please Help! Farmall H 1948 posted by early321 on November 14, 2014 at 06:39:33:
You need to start by separating electrical from fuel. After the stuff you did to the fuel system can you remove the plug in the carb and get a steady flow of fuel for a couple of minutes. Its possible something is stuck in the screen to the carb or in the needle valve. On the electrical its possible your coil is going bad. They will act up after running fine for a bit. You need to tell us more on the jump starting. Does the tractor not crank or cranks but doesn't start. Have you got a distributor or a mag. Distributor has to have either a working generator or a battery with a good charge and if you only depend on the battery sooner or later you have to recharge the battery. Is it 6 volt or 12 volt. Does your amp gauge show a charge? Your problem could be from a list of things and you have to rule them out one at a time to find the problem.
  Upload Photo  Select Gallery Photo  Attach Serial No List
