Here is what I would check. Check the cables from the battery to the starter, they must be heavy 6 volt cables. It sounds like you are not getting enough current to the starter. If they have been repaired with the ends that wire sides under a metal clamp with two 7/16 bolts, they corriode. I would replace them with new 6 volt cables. The starter switch could not be making a good connection, not allowing enough power to the starter. Next check the starter, it should be checked for worn brushes, weak springs on the brushes or shorted armature. If you haven't repaired starters it would be best to take it to a repair shop.
It sounds like you have tried things in the fuel system. You may want to try draining the fuel through the fuel system. If the carb has a drain try draining gas from the system or from the fuel line at the carb. Either way drain about a gallon if there is a blockage it will slow or stop draining. You said you cleaned the sediment bowl but did you clean the passage from the tank to the bowl. I had an A that was blocked with dirt, it would run ok in the summer and would not run good in the winter when plowing snow, all the dry gas in the world would not help. I have a model t ford that would run good until it got to less then a half tank of gas. When going up a hill or when it needed more power it would spit and spouder. The gas tank is gravity feed located under the seat (kind of like riding on a bomb)the housing of the sediment bowl was full on dirt.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
