Re: Please Help! Farmall H 1948
Posted by redforlife on November 14, 2014 at 16:57:04 from (68.234.121.124):
In Reply to: Please Help! Farmall H 1948 posted by early321 on November 14, 2014 at 06:39:33:
There should be (unless they are gone) a screen inside the top of sediment bowl and one inside where the fuel line screws into the carb. Check them and make sure they are clean. Float valve sticking is a common problem if it has sat for awhile. You either have a low charged battery, or bad connections. Is why you are having to jump. If you are jumping straight to the starter, you could possibly have a bad starter switch. You have to have a good generator and voltage regulater/cut out for tractor to keep battery charged. Generator also has to be polarized or it will run battery down instead of charging it up. Check ampe guage while it is running and make sure it is not showing a discharge with lights off (not on). For what its worth, a fully charged battery should start the tractor and it should run along time even if the generator is not working. You will be limited to just a few starts if that is the case though. Hope some of this helps.
  Upload Photo  Select Gallery Photo  Attach Serial No List
