Re: Re: Where do I check/drain trans fluid on a Super A
Posted by big fred on January 06, 2001 at 20:02:18 from (208.51.245.20):
In Reply to: Re: Where do I check/drain trans fluid on a Super A posted by gene b on January 06, 2001 at 19:23:53:
If it is the same as the A and B, there is a fill plug for the belt pulley, but it is the same reservoir. When you put in new bearings IH recommends you pour a pint of oil in the pulley housing first, to guarantee that the bearings get lubrication. After that they are oiled by means of drip channels cast into the trans housing. The oil reaches those channels by means of the oiler gear, so it takes a while for the first lube to reach it.
Post A Followup
: Re: Re: Re: Where do I check/drain trans fluid on a Super A
