Re: Magneto or Distributor?
Posted by pete 23 on November 15, 2014 at 10:10:31 from (74.33.82.156):
In Reply to: Magneto or Distributor? posted by dmat58 on November 14, 2014 at 21:37:45:
Do you plan on hand cranking it or use the electric starter? A battery ignition unit will give you a smoother running engine at lower engine speeds. Having worked on magnetos on IH tractors for many years I much prefer the battery ignition unit. It is much more adaptable to different engine options such as fire crater pistons, step head pistons etc.
Also, if you remove the DISTRIBUTOR from the magneto your engine will not run. Had to throw that in.
  Upload Photo  Select Gallery Photo  Attach Serial No List
