Re: Magneto or Distributor?
Posted by John T on November 15, 2014 at 12:16:42 from (216.249.72.121):
In Reply to: Magneto or Distributor? posted by dmat58 on November 14, 2014 at 21:37:45:
BOTH are good, each has advantages and disadvantages. Before tractors had batteries they sure came in handy lol. But with batteries and charging systems they gave way to battery powered coil distributor ignition systems. Still great in aviation uses.
Mag advantages are NO BATTERY REQUIRED.
disadvantages are usually no RPM based
variable spark advance like a distributor,
simply two timings, start and run timing.
more parts and maintenance due to impulse
assembly.
Distributor advantage variable RPM based spark
advance timing.
ability to produce (via stored
battery energy) and discharge more
spark energy then a mag especially at
low RPM.
disadvantage IF NO BATTTERY NO SPARK
There are others, its a persons own preferences.
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
