Re: Magneto or Distributor?
Posted by Janicholson on November 15, 2014 at 13:37:05 from (74.60.94.18):
In Reply to: Re: Magneto or Distributor? posted by Tom Fleming on November 15, 2014 at 12:51:34:
If a mag ignited tractor (such as a letter series Farmall) with no "spark" lever is setup to have close to perfect full power timing, it will idle with a noticeable unhappy sound, and moderate lumpiness. If the timing is changed while it is running back to a few degrees before TDC, it will smooth out and pick up RPM. Many a Farmall is operated cultivating, live planting, or doing light work idled down in a higher gear. The fuel efficiency and reduced engine heat are worth it. If they made timing controlled mags (or lever adjustable mags like the old old days) they would be equal. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
