I agree with both posts. Be sure to check the firing order, 1342 when you are looking at the cap from the rear. You can turn engine with distributor cap off to make sure of the rotation of rotor. Lot of times guys get 2&3 in the wrong spot on cap. The other thing to look at is the point gap. Make sure it is the same on both of the cams. There are only two cams that open the points as it turns engine speed and the reduction to one half engine speed is in the distributor section. It is not unusual for one cam to be worn slightly more than other and that will give you a different point opening on one versus the other. So, make sure the closest one is at least .013.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
