Re: #2 and #3 cylinders not firing?
Posted by El Toro on November 16, 2014 at 04:59:10 from (96.244.7.206):
In Reply to: #2 and #3 cylinders not firing? posted by Philip Poeppelman on November 15, 2014 at 17:44:54:
Remove sparkplug & bring No1 piston near the radiator to TDC on the
compression stroke. Then see where your rotor is pointing. Should be at the No1 plug tower. Hal
2-1
4-3 As the rotor rotates CW.
  Upload Photo  Select Gallery Photo  Attach Serial No List
