Posted by DeltaRed on November 16, 2014 at 09:11:24 from (65.100.145.34):
In Reply to: Checking H. P. on H posted by Dave Salway on November 16, 2014 at 01:18:41:
Best or only way to really know is to hook to a dyno.Drive(or haul) the tractor to the nearest shop with a dyno and find out. Most shops will gladly test for the normal shop rate.Usuually one hour will cover it.BTW,Last year I took my 1256 to be tested.They charged an hour.It was a healthy 130 HP.And you should have seen the 'coal'roll!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
