Re: Replacing Super H PTO seal
Posted by Zachary Hoyt on November 16, 2014 at 14:18:52 from (50.122.166.40):
In Reply to: Replacing Super H PTO seal posted by Lucas0522 on November 16, 2014 at 11:34:58:
I did one on an H years ago and only put one seal in it. Just see if
there are grooves worn in the shaft from the old seals, if there are
you may be able to move the seal in or out a bit to be on a less
worn spot. Another thing is to wrap a piece of paper around the
PTO before sliding the seal over the splined part as they can nick
the seal when sliding over. I parked mine in the door of the shed
so the rear end was about a foot higher than the front and that was
all it took to get the oil low enough to take the PTO off.
Zach
  Upload Photo  Select Gallery Photo  Attach Serial No List
