Re: 1950 M starts misses till warm
Posted by kevinj54 on November 16, 2014 at 14:34:48 from (50.42.187.96):
In Reply to: 1950 M starts misses till warm posted by Rod1555 on November 16, 2014 at 14:26:15:
Does it still have flat tops in it?
Compression will be lower than with domed pistons.
You may just have a bad valve also.
Did you check compression with throttle open and all plugs out?
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
