Re: Farming with a Farmall H
Posted by Centex Farmall on November 16, 2014 at 18:57:50 from (72.105.164.32):
In Reply to: Farming with a Farmall H posted by PineKnoll43 on November 16, 2014 at 15:44:57:
Pay attention to where the load is set on the carb, especially when you're really pulling at a high power setting. You don't want to lean out with a heavy load. For raking, drag harrow, etc you can lean it out.
Set per the manual then check a couple of plugs after a half hour or so. Soon you'll get a feel for how it should sound and smell when you've found the sweet spot.
  Upload Photo  Select Gallery Photo  Attach Serial No List
