Ident of a OD unit for a f20 - photo added
Posted by f20inmi on November 17, 2014 at 13:25:57 from (204.54.36.245):
third party image
Who wants to help this poor old F-20 guy identify the manufacturer of this O/D setup? It bolts to the clutch bell and I'm told you don't need to move the engine to install it. It contains 4 helical gears, a bronze shift fork, and is supposed to work like a Heisler 2 speed setup. I wasn't able to find a makers name on it, just a few stamped numbers on a couple parts. Any help would be appreciated. Thanks
  Upload Photo  Select Gallery Photo  Attach Serial No List
