1) If it has a Voltage Regulator and its field current control relay points are stuck closed, that could cause it. (I don't think it has a Low High headlight charge control system (but Ive seen all sorts of farmer modifications out there), but if it was always in high that can cause it or the wires shorted coming from FLD on genny
2) If the wire from FLD on Genny to FLD on VR was shorted out, another possible cause.
3) If the gennys Field is shorted near its output (wires to FLD Post inside) or if the FLD post was overtightened cracking the insulation causing it to short, that may cause it, or simply the wire from FLD is shorted somewhere.
4) Sure the battery itself is okay with no bad or shorted cells.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
