Re: Farming with a Farmall H
Posted by farmboy48 on November 17, 2014 at 19:34:04 from (208.107.15.166):
In Reply to: Farming with a Farmall H posted by PineKnoll43 on November 16, 2014 at 15:44:57:
I used to mow, rake and buck hay for 12 to 15 hours a day back in the early sixties with an H, only thing the old boy needed was a little oil once in a while, and gas every couple of days. Keep oil bath air cleaner clean, and a little grease once in a while. I still use a W6 and an M around the farm, both still work and run just fine. I do use lead additive in the gas tho, as the valves don't like the unleaded gasoline, and will burn the seats over time. If yours was rebuilt, you probably have new style valve seats and won't need it.
This post was edited by farmboy48 at 19:43:11 11/17/14.
