Re: TA / Clutch 560 D
Posted by Charlie on January 07, 2001 at 08:14:17 from (209.130.138.159):
In Reply to: TA / Clutch 560 D posted by Mylar on January 07, 2001 at 04:16:20:
I have the same problem with my 300 U. I have followed the I&T manual for adjustments and have the same problem. Is it possible I haven't adjusted it correctly or is there a point where something is worn enough there is no adjustment left. If so, would it be the main clutch or the TA clutch?
Post A Followup
: Re: Re: TA / Clutch 560 D
