Re: TA / Clutch 560 D
Posted by Les Repair on January 07, 2001 at 09:59:40 from (206.28.174.58):
In Reply to: TA / Clutch 560 D posted by Mylar on January 07, 2001 at 04:16:20:
The short linkage rod which goes from the clutch lever diagonally up to the TA lever needs to be made shorter. The simplest way to adjust this is turn the cleves in a turn or two. Drive up an incline in fourth gear, push in the clutch. If the tractor doesn't roll back shorten the rod a few more turns and try it again. This should all be done with the TA lever in the high position. If the rod is too short you will get a two speed clutch. In other words the tractor will start to move in low TA and then shift to high as the clutch is fully ingauged.
Post A Followup
: Re: Re: TA / Clutch 560 D
