Re: 12V v. 6V
Posted by leeedwin9 on November 18, 2014 at 21:53:09 from (208.103.28.189):
In Reply to: Re: 12V v. 6V posted by Owen Aaland on November 18, 2014 at 16:29:29:
The resistance changes at 6v too. Depends on air temp, engine wear, oil viscosity, etc. Starting with a 12v battery gives you so much more potential. My farm store sells group 1 6v batteries (wimpy) and the long thin 6v batteries that are used in tandem on the later diesels. The group 1 batteries are generally low amp batteries and offer short warranties. I was tired of getting new 6v batteries every 2-3 years when a 12v group 26 battery is cheaper to buy, rated double in cca and will last 5 years under average use. If somebody today designed a totally new Farmall M-type tractor with a low compression 4cyl gas engine you can bet it wouldn't feature a 6v starting, charging and lighting system.
  Upload Photo  Select Gallery Photo  Attach Serial No List
