Re: 12V v. 6V
Posted by tractorguy2 on November 19, 2014 at 07:12:11 from (64.147.38.155):
In Reply to: 12V v. 6V posted by Lucas0522 on November 18, 2014 at 10:26:04:
Six Volt systems need good heavy cables. Not
those 4 gauge Walmart cables that most people
want to use. Six volts also needs all the
ground connection to be clean ans free of rust.
I mean all ground connections. Not just the
connection on top of the battery.Where the
ground connects to the frame needs to be clean.
id the ground is on the battery box then the
connection between the box and the frame needs
to be clean.
The starter mounts to the engine need to be
clean and the back edges of the starter where
the backing back attaches needs to be clean.
Use star washers on all connections.
Use a good starter button. The contacts
inside the buttons tend to burn and not make
good contact after 40 years of use.
  Upload Photo  Select Gallery Photo  Attach Serial No List
