Re: MW Handcluth round 2
Posted by kevinj54 on November 19, 2014 at 12:35:27 from (162.17.149.81):
In Reply to: MW Handcluth round 2 posted by lee little on November 19, 2014 at 12:32:09:
lee little said: (quoted from post at 16:32:09 11/19/14) Will try on the pics but it will be tomorrow probably. Would it be ok to spray brake cleaner around the area where the assembly contacts the drum? I may try that after I heat it. I am cautious about forcing things because it seems when I have in the past something snaps and it gets expensive.
Did it work??? were you actually using it????
Like Slater said they can stick in the drum.
If you can get the cam off then you can take it out one piece at a time if you have to.
Oh, everything in there is expensive to non existent.
This post was edited by kevinj54 at 12:37:06 11/19/14.
