Re: 450 lp will start up but will not keep running
Posted by Centex Farmall on November 19, 2014 at 17:51:51 from (72.105.162.89):
In Reply to: Re: 450 lp will start up but will not keep running posted by rustyrelic on November 19, 2014 at 16:50:42:
The I&T manual has a small section on the Lp carb and regulator. It shows a simple cut-away. There's not much to them. On the Low side which you have apart it has the lever, thin steel plate with hole, diaghram and the pin. That's all there is. There's a boss cast into the regulator body that is the height that the long lever should be level with and lined up with.
I have a IH 450 manual with the LP supplement and it has the same information and diagrams as the I&T manual. It covers information on the steering as well. Parts for the Behlen type are NLA but they are pretty rugged and you may be able to fix yours.
If you can't find an I&T manual in time email me and I will try to scan in the pages and send them to you.
  Upload Photo  Select Gallery Photo  Attach Serial No List
