Posted by D Slater on November 20, 2014 at 16:19:27 from (184.14.183.33):
In Reply to: Farmall M Lift-all posted by Senator on November 19, 2014 at 18:07:15:
If question is about the inside lever on the end of the control shaft and outside lever. It has a key or a washer that acts as a key. Can't remember for sure at the moment which. Think its a washer but not going to say for sure. You can remove the lever retaining bolt, washer and then pull the shaft out for seal replacement if wanted.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
