Posted by Janicholson on November 21, 2014 at 21:25:43 from (74.60.94.18):
In Reply to: Snow plow posted by grumpydaniel on November 21, 2014 at 18:05:56:
Tractor electrical systems are very noisy. Manufacturers made no attempt to shield or dampen spikes in voltage caused by ignition or other systems. Digital meters read samples of voltage on a very short time window. The sample can be taken when the ignition sends a peak voltage of 200 volts into the wires, or it could be sampled between alternator pulses of output and read voltage showing no charging. A expensive digital can filter and average these spikes. Most cannot. Using an analog meter with a needle and scale, usually does a great job of averaging these spikes, showing accurate readings of "net" voltage. Having your alternator checked is simple and usually indicates accurately whether you need a replacement. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
