Re: Snow plow
Posted by Brownie450 on November 22, 2014 at 06:35:58 from (66.43.241.198):
In Reply to: Snow plow posted by grumpydaniel on November 21, 2014 at 18:05:56:
If it's a Delco with internal regulator, you can stick a small screwdriver in the D shaped hole on the back of the alt while running & see if charging increases.
Check the brushes.
If it does increase, the regulator is bad.
Digital meters give odd readings if used around alternators because the regulator puts out all kinds of high frequency signals/ hash.
  Upload Photo  Select Gallery Photo  Attach Serial No List
