Posted by Janicholson on November 22, 2014 at 14:02:10 from (74.60.94.18):
In Reply to: Super H carburetor posted by Lucas0522 on November 22, 2014 at 13:20:46:
The float tab that pushes the needle into the seat to control level can have a wear dent in it causing the needle to jam, or cock sideways a little. Flattening the tab, and adjusting the float is one solution. some require a touch of non lead solder applied to the tab, then flatten with abrasive paper on a popsickle stick to renew. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
