Posted by Owen Aaland on November 22, 2014 at 18:34:40 from (216.47.34.37):
In Reply to: Super H carburetor posted by Bob M on November 22, 2014 at 16:04:17:
Add one more cause. If the bowl gasket is installed upside down it will cover the bowl vent. Without a vent the incoming fuel just pushed out the metering tube before the needle and seat are closed.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
