Posted by Lucas0522 on November 22, 2014 at 18:47:57 from (69.111.104.92):
In Reply to: Super H carburetor posted by T in NE on November 22, 2014 at 13:20:46:
I had the throttle bushings replaced in the carb because they were bad.
I measured(with a Vernie caliper) from the bottom of the top half of the carb to the top of the float(float up and float down) and bent to get the right measurements per the the instructions that came the the rebuild kit. I didn't level my float and I have a feeling that's where my problem is.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
