I had a Super W-6 that had the same problem. Normally, I am a purist and will not switch to 12 volts and I don't like to do generator/alternator swaps. In my opinion, it spoils the original look of the tractor. So, out of pure stubbornness, here is what I did:
-Replaced the Super W-6 starter with a WD-6 starter which is 12 volts so it avoids the harsh engagement of using a 6 volt starter with a 12 volt battery.
-Removed the Super W-6 generator, removed the pulley and end plates from the generator. I installed these on a WD-6 generator and then re-installed the WD-6 generator on my Super W-6.
-Replaced the Super W-6 ignition coil with a 12 volt coil from a W-400D.
-Replaced the Super W-6 light bulbs with 12 volt bulbs.
-Swap the 6 volt battery for a 12 volt battery.
This wasn't difficult to do if you have the right parts tractor and a little bit of mechanical/electrical aptitude. It would be the most expensive 12 volts upgrade if you had to buy all of the parts. The end result was fantastic. A tractor that looked original, exempt for the bigger WD-6 starter and the 12 volt battery. It would start easily at -15F without the block heater being plugged in.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
