12v lights with factory 6v switch
Posted by LSGUNSS on November 23, 2014 at 17:57:02 from (69.29.83.107):
I have a 1952 Farmall H that is converted to 12V.
I have used the search and it seems like I can use the 6 volt light switch on a 12 volt system. If this is wrong someone please tell me. If I can use it could someone please post a picture or explain the way to hook it up? The 6v is a positive ground but the 12v is a negative ground so I am sure something has to be hooked up different on the switch. The lights were all cut and aftermarket lights were on the front where someone would just plug a wire in direct off the battery. Any help appreciated!
Thanks in advance guys.
