Re: MW 9 speed in a Farmall M, good option?
Posted by farmallhal on November 24, 2014 at 08:29:49 from (76.2.174.242):
In Reply to: MW 9 speed in a Farmall M, good option? posted by michaelr on November 24, 2014 at 06:37:13:
It will also over speed the belly hydraulic pump unless the M & W model has a disconnect like my 9 speed Heisler model does. Everything driven through the transmission except 5th (roadgear) will be increased significantly when engaged. I would be very cautious using the PTO and belly pump at high throttle settings without a disconnect. I believe they came into existence like noted by Delta for rotary hoes and hauling wagons at a respectful speed when needed, Hal.
  Upload Photo  Select Gallery Photo  Attach Serial No List
