Run a 13,000 watt generator with a H in overdrive and worked fine if there wasn't much of a load. The engine wasn't running fast enough to keep rpm's steady when to much load was added and voltage would begin dropping below acceptable levels.
It worked fine to run (2 refrigerators, lights, TV, furnace & well pump). Had to put back in standard drive to use( hot water heater, cook stove, clothes dryer etc). Used generator for 7 days(around 60 hrs) in Dec 07 after ice storm until power was restored, would not be without one.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
