Re: T20 Governor
Posted by nebraska cowman on November 25, 2014 at 10:43:28 from (166.182.3.219):
In Reply to: Re: T20 Governor posted by Jeff Wenner on November 25, 2014 at 07:09:48:
hard to tell without being there. For all I know the governor is not doing anything and yes, it could be running way too fast in that case. otherwise the aluminum knob should set the speed. No other linkages would matter except for slowing it down. I usually find the aluminum stub screwed down tight as the old farmer was trying to get all the speed he could. You would need a tach to check it. That's probably what I'd advise you. In absence of a tach check ground speed according to a chart. Here is the link to the nebraska test that will give you the specs
  Upload Photo  Select Gallery Photo  Attach Serial No List
