Re: IH 350 U new cushion starter drive
Posted by Owen Aaland on November 25, 2014 at 14:53:28 from (216.47.34.37):
In Reply to: IH 350 U new cushion starter drive posted by Duner Wi on November 25, 2014 at 06:33:09:
When you use the new style drive to replace the older style you no longer use the two washers with the larger ID. Use one thrust washer on each end of the armature. The other two fit over the armature shaft and served as a stop for the original drive.
