Sounds like the mix is not working for it. I only use ATF and have for years and most engines free up. The fact it turns some then stops means either the valve are stuck or you have rust ridge that your mix will not remove. Wick what you have in it out then FILL with ATF and also pour ATf down the exhaust and walk away for a week by he way before pouring it down the exhaust put the plugs back in. Then after a week use a 12 volt battery pull the plugs and use short fast taps on the starter button and I bet it frees up. Dextron ATF
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
