Re: Farmall M trying to get unstuck
Posted by Arnold Layne on November 26, 2014 at 06:28:44 from (66.146.251.145):
In Reply to: Farmall M trying to get unstuck posted by Eric Allen on November 25, 2014 at 18:20:12:
Yeah, you just as well pull the head and see what is wrong. If for some reason the cylinder walls need to be oiled???? then ATF will work just fine. It sounds like you have a lot of rust in the top of a cylinder, will an M open a valve far enough for a piston to hit it? Either way, squirting oil at it(or SwissMiss Hot Cocoa, even with the optional mini-marshmallows for that matter) isn't going to fix the problem.
  Upload Photo  Select Gallery Photo  Attach Serial No List
