Re: New to me Farmall 706 repairs?
Posted by mazemeister on November 26, 2014 at 14:34:16 from (104.148.251.168):
In Reply to: New to me Farmall 706 repairs? posted by tractorsam on November 26, 2014 at 10:45:03:
1. brakes are hydraulic actuated and dry. if the o rings or seals leak oil onto the linings, they will not stop very well and will make a grinding/growling sound when applied.
2.TA is hydraulic, the adjustment is in the linkage. look in the archives for tractor vet's instructions on ta/dump valve/ clutch adjustment. you need the engine running for dump valve adjustment.
3. the shift linkage does wear, lots of places that all add up. nothing that new parts won't fix.
4. the park brake isn't a brake as such, it is a pawl that engages between two teeth on the reverse gear. if it "jumps" the tip of the pawl could be worn/broken off. a rhythmic knocking sound when driving in reverse suggests someone knocked a tooth off the reverse gear by dropping it into park while rolling.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
