Re: A clutch
Posted by Jim Becker on November 27, 2014 at 08:19:31 from (173.84.240.213):
In Reply to: A clutch posted by cheif on November 27, 2014 at 05:47:03:
The Atwood Vacuum Machine Company established a division to build clutches in 1936. In 1938 they moved that operation to Auburn, Indiana under the name Auburn Manufacturing Company. So it is a lot like a Hydromatic transmission from General Motors. Oddly enough, Atwood was based in Rockford, Illinois.
It has been a while since I have touched a clutch in an A, but I believe the entire clutch disk is interchangeable with a Rockford disk. The rivet positions are different so you can't reline a disk with the wrong brand of lining. I believe there are some disks that were drilled for both rivet patterns.
I know I had a bad Rockford pressure plate "cover assembly" in a Cub. I had an Auburn on hand. So it went in with the original Rockford disk. It works fine.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
