Farmall Tractors Discussion Board
Re: Farmall B Rear-Mounted Mower
Posted by WayneR on January 23, 1999 at 14:42:47:
In Reply to: Farmall B Rear-Mounted Mower posted by RED on January 21, 1999 at 17:47:18:
I own a B and wouldn't mind having a sickle mower, but Wisconsin is a bit far from me. I haven't seen one of these sell to my knowledge. Maybe you should tell us more about it. Is it an IH or another brand? Is the sickle bar 5 or 7 feet long? Does it mount on the drawbar or is it attached to the rear wheel housings? I assume it is a hand lift. If it requires hydraulics, most B's won't be able to use it. Good luck.
Post a Followup
: Re: Re: Farmall B Rear-Mounted Mower
