Re: Narrow front end for 1066 1466
Posted by Jim Naden on November 27, 2014 at 17:09:00 from (70.198.69.219):
In Reply to: Narrow front end for 1066 1466 posted by D17puller on November 27, 2014 at 15:14:09:
The bolster housing casting is wider due to the wider frame width that started with the 66 series tractors. The pedestal is the same p/n 370253R1 on all models 706 up to 1486 and also 560. The spindle is the same dimensions whether using a 6 bolt or 8 bolt hub.
Source... wherever you can find one. Any used parts source should be able to supply the necessary pedestal. The wide bolster is a little harder to find.
