Re: What was Elotherm,harding of the crankshaft ?
Posted by Jim Becker on November 28, 2014 at 16:50:42 from (173.84.240.213):
In Reply to: What was Elotherm,harding of the crankshaft ? posted by Harry Klever on November 28, 2014 at 14:06:52:
Induction surface hardening. EF Northrup filed a patent on the basic idea in 1918. Ajax Electrothermic developed the Tocco hardening process. In the early 1920s, Midvale Steel Company did the first application of induction surface hardening, rolls of sheet steel, with Ajax equipment. By the early 1930s, Ohio Crankshaft Company was using Tocco hardening on crankshafts.
As already stated, Eotherm started research in 1938. They built their first crankshaft machine in 1942. Their process changed the shape of the inductor so it could rotate around the journal for more uniform heating than produced by the Tocco process, which uses a stationary inductor that wraps around the entire journal.
I can't give you any numbers on the thickness. It was fairly thin, but thick enough that a crankshaft regrind won't break through it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
