Re: Field repair of Super M inner axle bearing question
Posted by GordoSD on November 29, 2014 at 04:56:47 from (216.106.244.21):
In Reply to: Field repair of Super M inner axle bearing question posted by Rex Simpkins on November 29, 2014 at 03:48:11:
Remove the PTO
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
