Re: 504 block heater installation question
Posted by pete 23 on November 29, 2014 at 09:40:02 from (74.33.94.164):
In Reply to: 504 block heater installation question posted by maglinvinn on November 29, 2014 at 07:27:47:
There are several different styles so don't know what you have. Find welch plug most toward center of engine that you can get at. Knock it out(don't worry if it goes inside as you can reach in and get ahold of it to hook it out) and clean up the recess in block. Use a little lube on o-ring or packing depending on style. Make sure the element does not touch any thing inside of engine and point it what ever way gives the best clearance. Usually up.
  Upload Photo  Select Gallery Photo  Attach Serial No List
