Re: International 300 utility
Posted by Janicholson on November 29, 2014 at 12:35:29 from (74.60.94.18):
In Reply to: Re: International 300 utility posted by mrc958 on November 29, 2014 at 11:20:01:
A system can work like that, H and M Farmalls were (some years) wired in that way.
However!!
to do that the push button switch needs to be capable of 400 amps. The wires need to be the 0gauge I mentioned, and the switch will not fit in the dash. A Relay is easy to wire. A 12 gauge wire from the load side of the amp meter goes to the rubber push button near the key. from the push button a 12ga wire goes to the starter relay mounted on the starter, (small terminal)
The Negative Battery cable (non-grounded) attaches to the relay (post closest to the small terminal) the Opposite terminal attaches to the starter stud. Usually this is a strip of copper bent to connect (Buss Bar) for the 2 inches or so. Making one from a piece of 1/2" copper tubing flattened to allow drilling holes to fit the studs has been done to mimic a original non existent link. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
