Re: Trying to Start Farmall H
Posted by old on November 29, 2014 at 16:57:50 from (209.86.226.19):
In Reply to: Trying to Start Farmall H posted by Chris S. on November 29, 2014 at 16:36:07:
Mag or distributor system?? Need that info to help you. If a distributor try a hot wire from the battery to the coil ignition side and check for a good blue/white spark that will jump a 1/4 inch gap or more. Next pull the carb drain plug and make sure it has a good steady flow of gas for 3 plus minutes. Catch the gas to look for dirt /water etc and post back what you find
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
