Re: 656 lost hydraulics suddenly
Posted by Owen Aaland on November 29, 2014 at 19:20:15 from (216.47.34.37):
In Reply to: 656 lost hydraulics suddenly posted by fixerupper on November 29, 2014 at 18:04:20:
The 656 has a hydraulically engaged PTO like the larger tractors. You will need the engine running to check it. Using a pipe wrench will only tell you if the PTO brakes are working.
You can see the IPTO drive gear between the pressure plate and the release bearing if you remove the bottom cover and look up there. You should be able to see if the splines are chewed up.
I once drove a nail in between the worn out splines on a tractor to allow it it be driven a couple miles to the shop. Not a good solution but it did the job. Made it more difficult to split though. :lol:
