Re: charging a 6 volt
Posted by rustred on November 30, 2014 at 07:25:42 from (74.214.152.80):
In Reply to: charging a 6 volt posted by chuckj1954 on November 30, 2014 at 06:36:11:
charging on 15 amp is just fine, even on 40 for 10-15 min is fine then switch to 15. then you can turn to 2 amps after an hr. and just let it charge overnight if you want. 2 amps is just a trickle and can be left charging for any amount of time.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
